Andy96XLT
- October 5, 2007
- Branchburg NJ, Bethlehem PA
- 96 XLT
Hey everyone,
A week or so ago i noticed that my power steering was real stiff. I figured the fluid was low so i checked it and it was fine although very dirty. I drove it for a bit but the problem persisted so tonight i replaced the power steering pump. I was sure this was going to be it but i took it out for a drive and it is pretty much the same as before. I still have power steering but it is real stiff turning the wheel in both directions. I did a quick drive around the block and in a cul de sac i was able to turn the wheel all the way to one lock and drive in a circle without the car correcting itself. I did it the same way in the other direction with the same results.
Does this sound like my rack and pinion is gone? Possibly 2 bad power steering pumps? Should I go and have the power steering fluid flush? I have no fluid leaks and everything else on the car works but if its the rack and pinion I fear Im gonna have to junk the car as its not worth it to fix.
Any help is appreciated!!
