Power Steering Pump Reservoir Questions | Ford Explorer Forums
Kamaaina
Hawaii
'96 XLT 2wd
Hi all, a couple of questions here for my '96 4.0 OHV XLT: 1] What actually holds the power steering pump reservoir onto the pump assembly? 2] Can the reservoir be changed without removing the pump itself from the vehicle? Need to change or repair the reservoir as the return nipple has a crack & is leaking fluid. Thanks all!
It's a separate item:
My reservoir is part of the pump assembly and is not a remote reservoir. I don't see any fasteners holding the plastic reservoir onto the pump, the only penetration I see is the high pressure outlet fitting coming out the side. Just wondering if I remove that fitting will the reservoir slide off of the o-ring seal. I guess only one way to find out.....try it!
If its like the 94, with a slip on reservoir, you remove the pressure line fitting. Then you can wiggle the reservoir off the back of the pump. Seal kits are cheap, but I have never had any luck with them.
Thanks BKennedy. I got the reservoir off w/o removing the pump, wasn't that difficult. Replaced the big o-ring on the pump body and two o-rings on the high pressure outlet fitting & slid the reservoir on carefully. Before installing the reservoir I J-B welded two 3/4" neodymium magnets to the inside of the reservoir body to catch any metal debris floating around. Replaced the return rubber hose & also installed a filter on it. So far no leaks.
