Power Window question | Ford Explorer Forums - Serious Explorations
Savedtothebone
2002 ford explorer xlt
I have a 02 Ford Explorer. The passenger window is having an issue. I have replaced the master switch, passenger switch, and motor. The window motor moves in the up position but then power/lights go off when the down is pressed on both master and passenger switch. Thus will not make the motor roll the window down. I have checked the fuses all look good (both. The motor is not currently installed to make sure it is working in both directions. Is there a relay? What is causing the "power outage"
Ok did unplug the motor and the light goes off when pressed down in either master or passenger but not when up is pressed
yes looked like the reason was broke wire!! thanks for the help!!
