Power windows on 95 problem | Ford Explorer Forums
sberendt001
Ohio
Well...I have the 1995 Ford Explorer.And I'm sorry to say that I have a number of problems. Please help me out if you could because I am young and dumb.. First off..my power windows will not work on any side of the car except the driver side front seat...Full control on front driver side...The weird thing is...is that when somebody tries to roll them down and i see that....i do it for them...but as they are holding down...i cannot roll it down...As soon as they let go, i can.. Does anybody have a clue here? I'm thinking the Window lock button is stuck on lock...How can I take it apart and clean it if that is the case?
Also...When i'm at 55 ...I press the brake to slow...the whole vehicle begins to shake...including the steering wheel...Is the discs warped? Or no? I'm not sure...Whatever it is...could you give me an idea as to what it could be and how much it would cost? Any help would be much appreciated..
I'm sad to say that I am also having troubles with a mind of an own of windshield wipers. I read in here that you can clean the switch and it could work better...But how?
My check engine light comes on every now and again... I guess it's the gas cap...How the heck does that cause a problem? Is it fixable without buying a new gas cap?
I believe I cleared it all up...My tranny takes awhile to shift when i get up to 55..when it's cold..but i guess i understand that it is supposed to do that to warm you and the engine up..Not sure...Please help me out here.....Thank you..
The windows sound like a bad switch.
The rotors probably are warped.
The wipers issue sounds like a bad multi-function switch.
You can run a search for CEL codes and find out what code your throwing.
Pull the codes. Most autozones will pull them for free. Call ahead to verify.
