My98xplorer
- July 28, 2004
- lakeland fl
- 1998 Sport
I have had some trouble with my Ex starting, and after wiggling the negative cable, it started fine. I decided to replace it tonight, but when i did i didnt have the little ground wire that comes off the terminal grounded, and so the battery made a little fireworks show so i yanked the cable off the terminal and it was fine. i grounded the wire and thought eveything was ok, but when i went to start it, it didnt do anything. I have 12.2 volts on the battery, but it wont even turn over to start. I jump started it, and mmy battery light is on, and my gauge is way on the low side. While it was running, i disconnected the negative cable, and it died instantly. I think it may be either alternator or battery, maybe the volts are there but the amps arent? Did i fry it when i had all the sparks? Someone please help!!
