DefinitiveCars
- July 7, 2009
- SoCal
- 2013 Ex Sport
Hey guys,
I think a few of you have done HID's top and bottom. I just installed my new Kensun HID kits top and bottom. They were plug 'n' play. I was surprised that the installation doesn't require tapping the battery at all. I have a "plug 'n' play" HID kid for my BMW and you still had to tap the batt for power.
Well it seems that when you start up the car at night with the automatic lights on one of the fogs won't light up. If you turn the fogs off and then back on they will light up fine. You can turn them on and off after the car is running and everything is fine. But then when you turn the car completely off and then start the car again, one of them doesn't turn on again.
Seems like its the right one every time. But I thought the first time I
noticed it was the left. But since then seemed to be the right, so Im not
sure if I just mixed them up.
I'm thinking there is not enough power to start up all 4 HID at once. But I would think you guys would have the same problem as me if that was the case.
Did your kits tap the battery for power? Have you seen this before? Is there a solution?
Thanks,
D
Thanks,
D
