- October 6, 2008
- Location
- Va
- chesapeake virginia
- '96 xlt 4x4
Hey guys I'm having trouble trying to diagnose my throttle position sensor at the plug while it's disconnected reads normal but when I connect it and backprobe the connector it's about .70 volts too low on the signal side (4.3v) at WOT and once it's connected the reference is reading 4.02 v ...... Thought it was a bad sensor so I replaced it but I'm still getting the same readings the only driveability problems I have that are noticable is the clunk when coming to a stop but when I reset the pcm it doesn't do it until it completes it's drive cycle. And iv been told that this is most likely caused by tps problems.
Is there something else that could cause voltage drop ? Does the sensor ground itself in any way to the throttle body?
I've also noticed some slight changes in tps % data on my scanner.
