Project Lazyboy SAS... | Page 13 | Ford Explorer Forums
looks good.....so does double r's brother lol
Thanks man! I had Wrangler guy call out my SAS Fords as a joke so challenged him to wheel off his TJ against my 92 Ranger (Double R). He was quick to say time and date publicly but as soon as told him to message me to set it up not a peep out of him. HAHAHA he must have been feeling extra trollish that day....
I've shown up plenty of Ja-Heeps with my SAS ferds. I love rubbing it in their faces. The only heeps that give me a run for the money are the built JKs, and Juggies.
Edit: hit the button too soon, sorry.
Hey Stang, just wondering - after you cleared out all the IFS/IRS parts, what do you think the minimal lift possible for an SAS would be, while still having descent up travel?
I know that cursed frame hole and accompanying low spot in the rear could still be problematic. I was sort of thinking though that one could cut/grind that area for more clearance, then just reinforce the upper part and over the hole.
I'm quite interested in a x2 SAS, but mostly for additional strength, more availability of parts and to rid myself of 2wd. 37s and 7in of lift on a Sport Trac would be a sight, but also a massive poser-mobile given my realistic offroad needs.
Thanks and good luck finding a t-case.
You might be able to do get it down to 6-8 inch range on lift. Yeah still looking for a case. Every time I find an Ex that has the right case some has already nabbed it. I wish I would have known it was a special case I know I have passed on many of them last year.
WOW looks great.. Reminds me of my 99 I did but yours is way nicer...
Looks like I'm going to have to do the same on the wife's 02 eddy...
WOW is all i can say this is awesome! how much would you say total build cost was?
Around 2k at the moment. Still more to do.
Been busy with 4x4 Van just got it on the road a couple weeks ago.
Had some time today decided to give Lazy some love.
Out with the struts and in with some coils...
My math was right on first try. I was cheesing since I wasn't 100% sure.
Front is only about 1/2 higher then the rear now. Which is fine since I plan on building a winch bumper for it. Pass side after lunch.
So picking up some parts for some jobs I have coming up. And as I am walking I just about trip over 4411 just laying on the ground. I have been looking for this tcase for months. Plus I found all the parts I think I need for the power steering. Must be living right to just stumble across the 4411.
New toy should make life easier!
<a href="http://www.youtube.com/watch?v=t1wHRsdbqKE&feature=youtube_gdata_player">YouTube Link</a>
Nice!
How much did that set you back?
Around 10k I am still buying stuff for it but I am excited that it worked on the first try. My brother helped me get the program working. Should be offer a bolt in TTB to solid axle kit for the D30 here soon.
Had to modify the old oil adapter using the Lincoln adapter and an Explorer adapter I picked up. Using a small chunk of hose I was able to make clearance for the hydro lines for the steering box.
I read this whole thread a while back and it gave me inspiration to start SASing my 3rd gen explorer. Right now I'm just collecting parts to do the swap. I was wondering of you could go a little more into detail about what parts you used to make the steering work tho?
Just used a F150 box and combine stock steering intermediate shaft with F150 one. Then I built a brace to hold it. Not sure what else you want to know. I have a new box I need to swap in one I used was mock up box that I use for builds it works but it is a piece of junk. I need to finish the hydro return line. Been pretty busy and weather has been crappy so I have not finished it. My helper moved so I have been struggling to keep up working by myself.
