Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
sport track dana 30 sas project
- Thread starter atvfred
- Start date
Add an avatar, upload photo attachments, and more!.
atvfred
- January 29, 2006
- kamloops bc canada
- 2001 ford sport trac
here is my tracbar setup
And here you can se me cycling the suspension with the daystar stinger bumpstop tacked in place.
you can also see the side of my tracbar bracket with one steering box bolt going through the whole system.
here is my bumpstop pad and lower coil spring retainer built into one piece with a counter sunk allen bolt for a nice smooth bump surface
delexploder
- March 11, 2012
- Greenwood De.
- 97 ford explorer sport
Subscribed
damarble
- June 20, 2008
- Washington
- 21 Bronco & 88 Bronco II
That's the first time I've seen a D30 clamped in a bench vise, that got a chuckle out of me.
I'm really impressed with some of your stuff like the dished out frame for the coils and the limit straps back out of the way. I didn't even know the Ranger brakes upgrade was a thing, that is really cool.
Do you have a shot of the suspension at ride height? It looks like your tracbar and draglink are not the same angle and could induce bumpsteer.
It's too late now but an Aerostar steering shaft bolts up to your column and that box without any modifications.
Keep it up, you're doing great.
atvfred
- January 29, 2006
so ive got the truck on the road again. ive got a couple issues that i need to figure out. first off i have to install a sway bar with quick disconnects to see how much body roll i can get rid of. My rubicon express 5.5" xj coils are 180lb and are pretty soft. if they are to soft after the sway bar i might buy some stiffer ones, but i like how it rides offroad right now. I also have to run an 11" bilstien shock in the back instead of my 12" ones. 12" is a little to long with my current mount setup. Other than these couple little issues i love it. i will try to get some action shots this weekend.
atvfred
- January 29, 2006
The ranger brake thing is not a thing until now. lol. im hoping alot of people will use this info in the future. the whole reason i tried it was so i could reuse the ford wheel bearing to keep my origional abs. it works like a dream and such an easy mod to do. I dont have a suspension shot at ride height but the trac bar and drag link sit really good for the first 3-4" of up and down travel. i have not experienced any bump steer or deathwabble yet.
atvfred
- January 29, 2006
well. ive had the truck on the road for a few weeks now and ive some more pics. It flexs 905 on the RTI ramp, and i still have some more tweeking to do.
- December 16, 2010
- Greer, SC
- 2001 SAS'd Sport Trac
Looks great man!
atvfred
- January 29, 2006
Thanks. I will keep updating as I move along. I still have to build my skidplate for the new transmission crossmember, move my limit strap tabs so the don't hit each other on uptravel, start building my rear bumper, roof basket, and I'm sure there is more.
- December 16, 2010
- Greer, SC
Do you have some details on your crossmember? I recently made a new one for mine but it's not the best design and could use improvement.
MidnightRebel07
- March 6, 2010
- Pittsburgh, Pa.
- 2003 Explorer Sport Trac
Great fab work man. What size tires are you running? Roughly how much before and after lift did you get with the lift?
atvfred
- January 29, 2006
my crossmember side rails that bolt to the frame are 2" angle iron. with 2" square tube as the trans crossmember. My link mounts are welded to the 2" tube. my goal with this crossmember was ground clearance. i have quite a bit of angle on my links heading down to the diff but i would rather that then have my crossmember hanging 4-6" below the frame rail. the angle on my links is not enough to affect performance in any way.
Im running 33x10.5x15 bfg mt. this is mostly a commuter to and from work with weeknd playing so i wanted to keep my tires manageable for fuel mileage and power
Similar threads
- Replies
- 2
- Views
- 2,217
- Replies
- 24
- Views
- 20,093
- Replies
- 41
- Views
- 8,320
- Replies
- Views
- 2,191
- Replies
- 4
- Views
- 1,721
