These are not bad for use with a kit. I must say. Quick and easy, no drilling required. Expensive for what you get compared to a retrofit and the output is worse than the worst OEM HID projectors, but still, there is no glare, you get pretty nice high beams, you don't bug traffic coming on to you, you can use a kit, etc. For me since I am a DIYer, if I already had the headlight open, I would do a retrofit, but I can see where someone who doesn't want to tkae the time to do a retrofit would go this route. Just remember, PLEASE use a wiring harness on your HIDs. I don't want to see anyone fry the stock harness on here.
So in conclusion:
Pros:
Nice cutoff
Easy install
No modification to the reflector bowl.
Nice high beams.
No Glare
Rotational adjustment seems to be already taken care of.
Cons:
Bad hotspot (uneven light spread)
Width is so-so at best
Expensive for what you get, but much better ROI than just a kit alone.
You STILL have to open the headlights.
By the way OP, I hope you don't mind but someone over at HIDplanet wanted to know how the high beam looked so I posted your highbeam shot.
