1996BLKBauer
- June 24, 2011
- McHenry, IL
- 1996 Eddie Bauer AWD V8
Well winter is fianlly here, and I can no longer do projects on my Explorer outside, so I just bring them inside, the project for the next few weeks is a projector Retrofit on my '96 Eddie Bauer. Unlike most of the Retrofits, which use the Morimoto Mini projector housings, I am going to use something larger, only because I got them for free from work.
I will be using Ebay, blacked out headlights, with a clear cover. For the projector I will be using a projector assembly from a 2007-2013? GMC Acadia. The stickers on the projectors say Valeo, not sure on that company, but if they are good enough for factory GM stuff, I can trust it in my Ex.
These projectors are Bi-Xenon, so I will have to wire, both low beams, and high, with the servo. I have a pretty good idea on how to wire them, I just have to acquire so 9007 jumper harnesses, and find some old relays I got laying around, and spend some time wiring. I was able to get 6 head lamp assembly's, so that's 6 projectors, 6 bulbs, 6 ballasts, 6 wiring harnesses, basically 6 of everything I will need to do this project!!! I got them from work due to a recall pertaining to the filament type Daytime running lights, so the HID system still works great, once Parts kept them for a specified amount of time, they throw them out, and I take them out, and cut them up.
Time for pictures!!!
I only baked the lights apart, and hauled the box of projectors in so they can warm up, I did take apart one assembly to get just the projector housing out for mockup.
The Headlights I am modding, just Ebays ones, this is after I got them apart.
My box of projectors, not all of them, a few are in the garage still.
The assembly as they come out of the housing, the other one is the Day time running lights, that melts due to high heat.
Full harness:
After disassembly...
the reason I got all these, a broken, and melted housing...
The projector itself, multiple angles.
Scoping out the situation, I will need quite a bit of housing modification for this, but I'm not scared.
So far this is the progress I have, hoping to have one mocked up tomorrow, but we'll see. Let me know what you think, these are much larger then the Morimoto ones, and I believe the factory bulbs are in the range of 6k, so its basically perfect for what I want.
Full harness:
