jtb1689
- August 23, 2008
- Woodinville, WA
- '93 Sport Eddie Bauer
So I went in recently to replace the gasket on the timing cover. While I was at it put in a brand new water pump and gasket, also did the intake manifold gaskets and valve cover gaskets all that good stuff along with a new radiator (oem equivalent). However I now have a problem. When driving, after accelerating (putting the rpm's up) and after I let the rpm's come back down, my temprature spikes. Either all they way up to the white line just before crossing into the red, or somewhere between the L in NORMAL and that white line. Then, after a few seconds, the temp goes back down to normal right where it should be on the R.
At first I thought maybe it was the thermostat, should have done it when I took everything else off anyway. So I did, still have the same issue. Maybe the water pump, but that is highly unlikely since It's brand new and coolant does flow. I checked the upper radiator hose when the temp spiked, it was completely pressureless, however it was nice and firm like it should be once the temp was normal. I'm pretty sure I've just got some airpockets from when I bled the whole system out replacing everything. So, on to the big question:
Is there a technique to burping the cooling system on these 1st gens? Or, any other ideas on what to do or what it could be? Any and all suggestions welcome. Thanks in advance, all you guys on here are awesome.
Edit: PS, No white smoke out exhaust and the only loss of coolant I've had is when revving the engine up with the radiator cap off, watching the coolant go down, then letting it rev down and have the coolant come spraying out. Everytime thinking maybe I got the air bubble only to find out it all happened again next time around.
