Q-Logic Stealthbox VS JL Audio Stealthbox: Which would sound Better? | Ford Explorer Forums
OVERKILL700HP
New Jersey
94 XLT Auto 4x4
Which would sound better provided that they have the same exact JL Audio 10 in woofer?
Thanks ahead.
They would sound the same. At least to me since I had both. The JL is built better & I think fits a little better also.
The Q-Logic is made of plastic and the JL is made of fibreglass. I have the JL steathbox and love it. My local Car audio store had a Q-Logic box there and after looking and holding it, it just felt kinda flimsy and cheap(just my opinion). So I ended up buying the JL Stealth on Ebay for $200.
As far as sound quality, I dont know the difference because I have never heard the Q-Logic perform, But i know the JL sounds great.
q-logic is flimsy and cheap. I have a q-logic 12" box and it is falling apart. The edges are comming off and it is starting to separate. The jl audio is well worth the extra money for sound quality purposes and sturdiness.
I have the Q-Logic box with a JL 8" sub in it. It seems too small for it, because it is making this weird noise that I can't get to stop. I am pretty sure it is the box, so I would go with the JL box.
Did you add any damping material Jared? You can increase the apparent volume of a box by up to 10% with damping material as well as damp internal resonances and modals .... also check that the speaker is sealed, air leaks can make it 'honk' as can the port if it is ported and not tuned to the speaker (one size fits all woofers NEVER applies to ports) ... put a piece of cloth over the port stretched tight and secure it temporarily with a rubber band to see if it helps if you suspect a port is 'honking' .... this slows the air movement through the port damping out the 'honk'
The one thing the JL stealth box is the correct size enclosure for the sub in it. The Q-Logic is a universal box fit for the Explorer. It is made for differant speakers, which would react and sound differant. not a certin speaker like the JL box is made for the JL sub.
Tim
doesnt mtx make one too? i forget but i thought they did. anyone know about that one?
