Devan
- April 18, 2017
- Location
- central jerz
- 01 BoostedXPLR Sport
- Callsign
- Devman
I jus got done replacing blown head gaskets nd replacing a busted chain guide on the rear for the passenger side cylinder head. I got everything tightened bak up and have no problem turning the motor over by hand however as i do so the chain guides that lay directly on the tensioners push the tensioners in and then when i turn the motor over a lil more they pop out. Both sides do this. Is this normal? I kno their prolly compressing all the way cuz their is no oil pressure or oil in the tensioners but i jus wanted to make sure this is normal for the tensioners to compress all the way and then pop out when you turn the motor over by hand counter clockwise. If nec i can take a vid and post a youtube link so u can see what im talking about. Been building performance builds for over a decade nd worked as a ford tech for 3 yrs till i outgrew my dealership but i am extremely delicate when it comes to timing drives, especially with one like this german designed 4.0 sohc. Im almost positive what im seeing is normal but i just wanted to check with somebody that has a decent amount of experience with the timing drive on the 4.0 sohc. Also if i bled the air out of the tensioners by compressing the tensioner and then submerging it in oil and then letting the tensioner uncompress so that it sucks oil into the tensioner, would they still fully compress and pop out when i turn the motor over by hand or would it just push the oil out or would the tensioner not compress as much when turning the motor over by hand? That ill find out soon enuff tho lol. But any help asap wuld be greatly appreciated. Been working on my BoostedXPLR Sport for over a week straight from wake till sleep and i shuld be rdy to fire it up today so a lil quick help would be extremely appreciated. Thx in advance.
