Yes/No, unless you have a wiring book for the power mic you have or plan to buy, you will have a problem with re-wiring a mic.
A good shop will have the wiring books required.
Ask the shop if they sell mics without the connectors, I can't believe they don't, and see if they will wire it to work with your radio.
Are you going to try and re-wire your mic with a new connector or just buy a new mic?
My thoughts go along this line:
1) Have your mic checkout by a good shop, (what makes a good shop I am not sure, just watch what they are trying to put over on you).
2) Have your mic cleaned up and have the connector disassemblied and cleaned, then re-wired to the existing connector. (Actually you may be able to do this, just disassembly, write all the wire colors down and where they go, and de-solder the connections, clean everything with alcohol, and then re-assembly the oposite way of taking it apart). Try it out, it may work.
3)Buy new microphone from a radio shop have them supply everything and attach the connector. (that way if something goes wrong you have somewhere to return it).
4) Buy on-line. (I know from experience that you can buy mics pre-wire for most radios).
5) If all else fails and you are not able to get a mic to fit your needs, say sc$ew it and buy a new Uniden CB or something like it and start all over again with known good radio/mic.
If all else fail you can shoot me, how's that... only kidding.
I will say this when you buy or are given a used radio it is sometimes more of a problem than getting a smaller new one.
If you are just getting started in radios and have all of these little problem and don't enjoy it, then it is one way to get discouraged quickly.
Later on we will try to make a HAM of you and we don't need you having to much trouble now.
Good Luck,
If you find this confusing and want to talk more with a llittle faster turn around, e-mail me at "n1mau@gis.net".
No problem with e-mailing, I alway like to talk about radios.
