blueoval52
- August 26, 2008
- Roanoke,VA
- 92 Ranger xlt
Anybody ever blow up there 4.0 litre v6 useing Royal Purple oil?
Well I drove back and for about 4000 more miles and then let it set for 7 days straight. got in it to go for a short ride and it sounded like htere was no oil in the engine and everything inside was doing its best to get out. I shut it off , waited and restarted 3 more times before I could jhear myself think. It has multiple lifters/pushrod/rocker noise coming and going and a rod knock thta would make you kringe.
you just answered your own question.
the sitting for a week has probably caused the oil to leakdown so the lifters are making noise.
royal purple is not your problem. i know mechjames IRL and he runs RP 5W-30 in his 94 XLT (and his pulsar) and it's not detrimental to his performance. spectrographically the motor, i think, is screwed, but you'd better take that up with him.(just kidding james, but 110ppm iron is too much!)
but anyways, about yours. RP is a perfectly good oil... if its just because its been sitting and it was fine last time, check your oil level.. if its okay, start it up and run it at about 2000RPM to build oil pressure quickly. that's the only thing i can think of.
most oil pumps, especially old ones don't like the thinner synthetics, causing your fuel pressure to be low.
synthetic oil should always be run at the widest range, i personally use 10w40 in my bronco II, and 5w50 in my 300zx.
At times the synthetic oil is too thin and the worn engines tolerances have opened up and can cause the rattle's some here because the new oil is so thin.
This engine had been surfaced properly and didn't have a problem till I switched oil. What did I do wrong. I run 10/30 in winter here so should I have put 20/50?
