DB_1
Elite Ranger
- October 23, 2001
- La Quinta, Ca.
- 97 SC Ranger xlt
I've put off finishing my bobbed bed, I have to weld in the inner piece of sheet metal but its gonna be a real pain in the :mattmoon:
So I've decided to do something a little easier and make a rear bumper. I started with 2"x4"x.120 wall tubing and 45'd the ends, similar to a TJ bumper.
I then capped the ends with the same thickness material as the tubing.
For the brackets, i'm going to use 2x4 tubing again welded to the bumper itself then drill 4 holes on each side, the bolts will run throught the frame, to the welded brackets and finally to a plate that will slip inside the brackets with welded nuts on it. I will also weld on a 2x2 crossmember to give it more support. I need to make a run down to Schorr metals in Anaheim to get more material and they also have weld on tow rings...kinda like D-rings but these are non removabale.
Here's a couple pics of the bumper mocked up:
