sully81
- January 15, 2009
- Cleveland, OHIO
- '00 Ranger
Hi there, 1st timer here. Somewhat mechanically inclined, looking for some advice so I don't get hosed by the repair shop.
I've got a '00 Ford Ranger, 4.0L V6, 4x4, 80,000 miles. No major transmission work ever done, only a sensor replaced back when it was under warranty.
Moved it today to snowblow the driveway (coldest day of the year), got out, noticed a trail of fluid leading under the truck. Later, tried to move it back, I could shift but it wouldn't engage in D, 1, or 2. Reverse worked for a second. 4x4 High didn't, but Low did for a couple minutes, however the dash light still read 4x4 High. No check engine lights, O/D did not flash. All fluids were full, including tranny, but antifreeze was low. There are no engine vacuum leaks as far as I can tell, and the heater is blowing warm air, so I don't think the coolant is leaking anywhere, which would cause the tranny to overheat and rupture a seal.
Leak stops when I shut it off, but as soon as I start up I can see two steady streams of fluid, some of which hitting the cat converter and burning. It's definitely a reddish color, distinct smell. Before this, there was no hard shifting or slippage, no noises and no leak before today, everything was tip top.
Basically I'm wondering where the leak could be coming from, to narrow down the possibilities. If it's a gasket or seal leak, am I correct in thinking this isn't a total rebuild? The transmission operates on a vacuum, which would explain why it suddenly wouldn't move without fluid pressure, correct? Any advice would be welcome, thanks for reading.
Joe
Joe
