RAP Module question | Ford Explorer Forums
RAP Module question
4X4 X
SPARKS, NV
98 XLT
Hey everyone, this is my first thread and wont be my last. I have a question about changing the RAP Module, my ex girlfriend knows the permant factory code for the keypad and i want to change it. I know i have to change the RAP Module in the back, and i also have to change the keyless remote codes. My question is how do i change the remote codes, and is there anything else i have to do.
Thanks,
4X4 X
Changing the keyless code
While it is true that in order to change the factory code you must change the module, it may be possible to inut your own code by following a certain routine that should be spelled out in the owners manual. The factory code will still be retained but you will also have your own code that will also open te door.
He is trying to keep his ex-girlfriend out though, and she knows the factory code.
Sorry, I can't help with your questions though.
Welcome Aboard Though!!!:D
You have to change out the RAP modules and re-program the remotes to accept the new module.. If I remember right you have to turn the cycle in ignition 8 times and leave it in the on position and press a button on the remotes and then turn the ignition off.
Oops, forgot I had these pics on this computer.:confused:
Hey you guys are awsome...... thanks for the good info, and getting back to me so fast. I really appreciate it.
Thanks,
4X4 X
while we're on the subject... is there anyway to use a factory fob witht he extra trunk button to actuate an extra thing (like if I replaced my module with one from a truck witht he side code and the trunk button, I want to automate the rear gate)
