Tony H
- September 4, 2003
- New York, Wading River (that's on Long Island)
- '91 Eddie Bauer
Now for the passenger side, same as the drivers side but to remove the axle you will need to remove the 3rd member and pull the c-clip to be able to remove the axle. I know a dana 44 is that way, with a c-clip on the passenger side only, but to make sure on the dana 35 pull the spindle first and see if the axle will come out because if I'm wrong I would hate to put you through all that. .
PASSENGER SIDE
If you are Just doing OUTER 'U' joints, you can separate the axle at the Rubber boot. not at the differential. Mark the axle on both sides of the Rubber Boot so you put it back together in the same orientation, cut the wire band and the axle halves will come apart.
