Re-Gearing is this right | Page 3 | Ford Explorer Forums
where did you find urs at unclemeat
unclemeat said:
I have a Truetrac in the front D-35, works great. It is hard to steer in hard surfaces.
did you use one for a standard rotation D-35 or did you actually have one specified for the D-35R?
i definatly would take a TrueTrac for the front, i am just under the impression that they dont make them.
I got it from a member on the board with a 4.56 ratio installed in a pumpkin. I think he got it from another offroad enthusist board (Ranger). It was a reverse rotation D-35, it bolted right up to the front axle. I had the a shop check and install it. I do not think that it is a different part number than standard rotation D-35. There has been some discussion on this topic on the forum. If you do a search within the last year you should be able to find the information. You may also may want to check therangerstation.com
