aballard5
- March 15, 2010
- Proctorville, Ohio
- '03 Sport Trac
Hello all!
I have been reading the forum for a while, but this is the first time I've posted.
I have been experiencing a problem for quite some time in my '03 Sport Trac with a fuse blowing every time I turn on the A/C-heater at the back of my center console. On the rear of the console, I have two vents at the top with some controls below it, which consist of a switch of the left side to toggle between upper and lower vents, and a switch on the right for three speed settings for the fan. There are also controls in between the two switches for the radio, but those seem to be working just fine.
When I first noticed the rear fan was not working, I looked at the fuse diagram and found a 5A fuse at position 31 in the panel located on the diver’s side of the dashboard. I pulled the fuse, saw it was blown and replaced.
If I start the truck, then turn on the rear fan, blower works just fine, but the fuse will blow again on the next start, or it will automatically blow on the first start if I have the blower on when I start it. Everything I have found on the internet seems to indicate a grounding problem, but I don’t know how to diagnose. Does anyone have a suggestion? Thanks in advance.
