zavetsky
- August 6, 2000
- '94 XLT 4x4
Ok, I JUST did a rear brake job when I replaced both rear brake cylinders..........a couple months ago.......
Well, the rear axle seal on the drivers side is now leaking which means another brake job........and new seals/bearings.......
How tough is this?? The CHilton's manual shows it as being very straightforward..........remove diff cover, remove bolt, remove pinion shaft, remove c clips, remove axles, remove axle & seal as unit with special tool........
.........so, any tricks or tips to make this go easy?? Do I need a special tool to pull the bearings and seals or can I easily use normal tools???
ANy advise would be appreciated............I love the truck, but it seems like SO many things are starting to go!
Thanks in advance!
Thanks in advance!
