JoshMcMadMac
- December 20, 2009
- Waynesboro, PA
- 2002 Mercury Mountaineer
I have a 2002 Mountaineer, 4.6L, 2-wheel drive. I just changed the rear differential fluid, pursuant to a pinion seal replacement. As far as I am aware, the 8.8" IRS was the only option on this vehicle, with a choice of limited-slip or not. I checked the manual before all of this and it states a capacity of 5.5 - 5.8 pints...almost 3 quarts. This made me very confused when I could not quite manage 2 quarts into it, even with the rear jacked up. I then searched around a bit, and there are several threads here that go over this and how the capacity is just under 2 quarts. Here are two examples:
http://www.explorerforum.com/forums/showthread.php?t=289561
http://www.explorerforum.com/forums/showthread.php?t=248273
The first link even has a picture from a .pdf version of the 2004 manual showing 3.5 pints...and I do not think anything changed for the rear differential between 2002 and 2004. Is the manual incorrect, or perhaps a carry-over mistake from the previous generation?
