chris8428
- May 11, 2014
- New Mexico
- 2005 Ford Explorer
Morning,
After searching on this site and reading these threads along with one or two others:
www.explorerforum.com
I was going to change the rear differential fluid as I am probably overdue. I have 167,x.. on the car. I changed the rear diff fluid at 130,x.. miles but I cannot remember if I used synthetic or conventional. At this point does it make a difference? One of these thread states synthetic is called for in the rear differential. If it does have conventional and I go with synthetic do I risk leaks? I have the 3.55 open differential so I know I do not need a friction additive the limited slip models do.
Or, is this just one of those topic we tend to overthink and just getting it done is what is most important?
Chris
Questions about differential fluid
Hi guys, I'm planning on change the rear differential fluid and i'd like to know which brand is the most reliable to use and how can I make sure I need to use the additive in a simple way. I've been reading lots of posts here on the forum so if you know one that explains all, please put the...
Changing Differential Fluids
Going to hopefully change the front and rear differential lube this weekend. My Hayne's has the rear needing about 1.5qts, but mentions nothing about the front differential. Can anyone guess as to how much fluid is in the front? Cornburner, you used 75W-140 in both right? Any real benefit...
Chris
