Rear Disc Brake Conversion on 2002
Hawkrod
Apple Valley, Ca
2002 Explorer Sport
Okay, I searched and read every thread on rear disc brakes that came up in search but couldn’t find any discussions that told me enough to make me feel comfortable. Background: I had an 02 Sport 5 speed that I have lovingly cared for and rebuilt over and over. A lady turned left in front of me and I creamed her and my Sport. I’m looking at an 02 Sport Trac with fairly low miles. I already have my old rear with a 3.73 Trac Lok and disc brakes. The ST has drum rears. I’ve read that I need to remove the proportioning valve and bolt my rear in. Is it really that simple? What about the ABS unit, are they the same? I bought my Sport back from the insurance because I have spent a bit on it and have some nice things I’ll also be switching to the new car if I buy it but I’m still on the fence. I really want the 4 wheel discs. If there is a thread I missed, I apologize but please direct me to it. Thanks in advance...
koda2000
x
The Ford 8.8" rear diff's on all Gen II Explorers (2 doors, 4 doors, Sport Tracs an, Mountaineers) other than gear ratio, are all the same unit. IDK why Ford decided to put rear drums on the 2001-2002 Sport Trac, but the disc brake parts from another Explorer will bolt right on in place of the drum parts. I know this is so because I took a 4 door Explorer disc rear diff, converted it to drum and swapped it into my '01 Sport Trac. No modifications to the diff were required.
Here's the rub... disc and drum brakes require a different volume of pressurized fluid to work correctly. Usually the master cylinders are different, the proportioning valves are different an the rear brake lines require a residual valve to prevent fluid pressure from draining back toward the master cyl. Disc brake calipers require a little bit of residual line pressure (around 10 psi) to work correctly. Some here will say they've converted their drum brakes to disc brakes without making any changes, other than rear flex lines and perhaps the parking brake cables, to their drum system and that their rear disc's work fine. These people don't know what they're talking about. Don't' believe me? Contact someone like Wilwood or SBC and ask their tech experts. Consider the difference in fluid volume between a drum brake tiny wheel cylinder and a disc brake caliper. Without having residual valves in the system disc brake pads tend to back off the rotor slightly (especially if rotors are true) and will cause a low/lower pedal that requires an extra pump when braking.
What's wrong with having rear drums? Your rear brakes only provide 20-25% of your vehicle's braking power and drums can easily handle that. Don't get me wrong there are benefits to disc brakes over drum brakes. Ease of maintenance, more consistent braking and less issue with moister.
As long as we're on the subject of brake safety, another thing that drives me crazy is people who insist that home plumbing compression fittings are okay to use to repair your brake system and that they've done it for years w/out any problem. This is just stupid and unsafe. Consider that a compression fitting used in a home's water system only has to withstand around 60 PSI and that In an emergency braking situation you brake line pressure can be 1,200 psi.
Nctruckman
NC
1994 Explorer XLT 4-Dr
If you're not sure what parts interchange, check part numbers, sport Trac master cylinders are the same 2001-2005. I'm more familiar with drum rear trucks, but I'll take rear hydraulic discs any day over rear drums, less moving parts. If they made a decent kit with a functional parking brake, I'd swap my 89 f250 asap.
E Rear end Help! 2001-2005 Explorer Sport Trac 2
K Cracked rear 2001-2005 Explorer Sport Trac 6
P '02 Rear Window Replacement 2001-2005 Explorer Sport Trac 0
E Hi, I need help with my sport trac. My Driver side rear brake light/ turn signal is not working. 2001-2005 Explorer Sport Trac 2
T question about rear breaks 2001-2005 Explorer Sport Trac 4
T Rear main oil seal leak 01 Sport Trac 2001-2005 Explorer Sport Trac 2
K Rear Window Weather Seal HELP 2001-2005 Explorer Sport Trac 0
K notice rear differential leaking 2001-2005 Explorer Sport Trac 9
S Rear differential housing ABS sensor replacement 2001-2005 Explorer Sport Trac 10
M Rear bed bolt nut access? 2001-2005 Explorer Sport Trac 5
KA3NXN Rear brakes smoking 2001-2005 Explorer Sport Trac 1
G Help please, rear window washer, '03 2001-2005 Explorer Sport Trac 0
D Scrapping from rear wheel area 2001-2005 Explorer Sport Trac 3
A Door Lock Actuator Part Front vs. Rear 2001-2005 Explorer Sport Trac 6
D Rear Bearings for 2003 Sport Trac 4x4 2001-2005 Explorer Sport Trac 8
C Rear vent power window help needed 2001-2005 Explorer Sport Trac 10
H Changing trans and rear differential fluid 2001-2005 Explorer Sport Trac 3
J 2003 Sport Trac Rear Quarter Panel removal/installation 2001-2005 Explorer Sport Trac 1
M Rear center window regulator 2001-2005 Explorer Sport Trac 0
M Help with Rear Window Motor 2001-2005 Explorer Sport Trac 0
B Center rear window won’t relearn 2001-2005 Explorer Sport Trac 4
D 04 explorer xlt rear axle assembly issue 2001-2005 Explorer Sport Trac 1
C Passenger/Rear Timing Chain Guide needs to be replaced 2001-2005 Explorer Sport Trac 4
M Rear drivers side door wont open 2001-2005 Explorer Sport Trac 5
J Only getting air from rear vents? 2001-2005 Explorer Sport Trac 7
B Looking for rear end w drums for 02 ST 4x4 4.10 gears 2001-2005 Explorer Sport Trac 2
T Never seen a rear main like this one before... 2001-2005 Explorer Sport Trac 6
O Rear sway bar end links 2001-2005 Explorer Sport Trac 9
L No Speedometer, but no ABS light, is it still the VSS on the rear end? 2001-2005 Explorer Sport Trac 3
S 2005 Sport trac rear parking brake shoes 2001-2005 Explorer Sport Trac 12
koda2000 Rear window issue 2001-2005 Explorer Sport Trac 4
S Rear power window switch 2001-2005 Explorer Sport Trac 0
T Rear wiper and washer not working 2001-2005 Explorer Sport Trac 0
A Rear shackle replacements 2001-2005 Explorer Sport Trac 2
P My rear window is going up and down. I can't get it to stay up 2001-2005 Explorer Sport Trac 1
tlambing Driver's Side Rear Door Seal Part Number 4L2Z26247A51AA 2001-2005 Explorer Sport Trac 0
P 04 Explorer EB 4.6L-Rear Toe Link Adjustment Question 2001-2005 Explorer Sport Trac 0
R How Can You Tell The Difference Between an Oil Pan Lower Gasket Leak and a Rear Main Seal Leak? 2001-2005 Explorer Sport Trac 10
swshawaii Rear Child Seat Anchor Cover Fell Off 2001-2005 Explorer Sport Trac 3
C 04 ST rear shoulder belt anchor help 2001-2005 Explorer Sport Trac 0
C Power Rear View Mirrors 2001-2005 Explorer Sport Trac 8
J Rear-End Driver's Side Sag 2001-2005 Explorer Sport Trac 2
C Rear window question 2001-2005 Explorer Sport Trac 5
S rear brake rotors 2001-2005 Explorer Sport Trac 3
K Main Rear Seal 2001-2005 Explorer Sport Trac 9
T Snapped rear jackshaft attachment bolt Sport Trac 2001-2005 Explorer Sport Trac 3
koda2000 '01 ST RH rear brake backing plate 2001-2005 Explorer Sport Trac 2
R 01 ST - Additive to Stop Front & Rear Differential Leak? 2001-2005 Explorer Sport Trac 3
J Help with driver rear turn signal and brake light 2001-2005 Explorer Sport Trac 5
F Rear shock removal not fun. 2001-2005 Explorer Sport Trac 8
Similar threads
