krs_med
- March 11, 2014
- South carolina
- 2003 Explorer Sport Trac
I assumed it was the motor on my 2003 Sport Trac. When you press for the window to come down the motor tries to work. (the track is down) When you try to raise the window it does nothing. The led's on the switch go out also when you try to raise window. Replaced motor and its still doing the What am I missing? The old motor does not work with it just plugged in and not mounted. I didn't check the new one. Could a bad switch front are back cause this? Any help are a wiring diagram would be great. Thanks for your time. Keith
