02_3.0_Edge
- April 3, 2003
- New Kent, VA
- 96 4x4 Sport
I have a 02 Ranger that I just replaced the rear axle assembly. I used the brakes that were on the new axle. It is out of an 03 ranger that had 2,000 miles. When I hooked everything up and went to bleed the brakes the fluid will not come out of the center hole but instead seeps out the threads when I loosen them on both sides. What could be the problem?
I bleed it at the master cylinder and that worked fine. What can I do? Any help would be greatly appreciated.
