Rear link bushing kit? | Ford Explorer Forums
junglejet
Boston
Mountaineer, 99 5.0 AWD
Does anyone know if a bushing kit exist for the rear stabalizer links on 99 mounty? has anyone re-bushing these before?
Thanks.
Let me move this out of the new member forum for you. you'lll probably have better luck in here.
Thanks i didn't realize i could have posted here.
After doing some reserch, i was able to find a bushing only link (mfg by Moog)kit from Advance Auto.
I bought the bushing kit from advance auto (Part No.
K80085) and installed last Saturday. Each kit comes with 4 thermoplastic bushing (2 top 2 bottom), one bolt, nut, and washer for lower end connection to sway bar.
The top bolt mounted for the frame was reused the kit also included a metal bushing for the top. This was a straight forward installation soaking both top and bottom blots with PB blaster before loosening is recomended.
You will need a 6 inch extension for top bolts on both sides, to work aroung fuel lines on L, and muffler pipe on right.
This simple installation really made a difference in the ride comfort, prior to replacing the bushings the rear was loose.
