jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
Does anyone have a picture of their rear sway bar? The typical sway bar I have seen has the ""hoop"" part towards the top of the pumpkin but I swear I saw one in the junkyard the other day on a 98 5.0 where the hoop part was towards the bottom of the pumpkin. So would like to see or know if they made different sway bars?
I'm using one from a 97 in my lowered 94 ranger but had to mount it upside down to clear.the sway bar I have mounts normally with the hoop part up, I need it to have hoop part down.it can be mounted upside down but if you have noticed the sway bar is not square. If you unbolt it your notice one side sits lower than the other, I'm pretty sure this is to counter act the weight of the gas tank and driver being on one side.in "theory" it helps ""lift"" the driver side.mounting it upside down would do the opposite and this is what's happening to mine.
Typical way it mounts..I need the ""hoop"" part to face the bottom. .(my explorer)
Edit. ....appears I had it wrong in my explorer!
Same bar, took it off the ex and mounted it in my ranger but you can see I had to mount it upside down and I think this is loading the frame up because its made to off set the weight of the driver and gas tank, upside down it loading up the driverside instead.
