Lazzman
- June 27, 2005
- Massachusetts
- 1998 Sport 4wd- V6 Sohc
Does anyone know the size of the stock explorer rear sway bar?
With the new poly kit I bought I got the sway bar bushings but the hole is a bit to small. It is the size of a dime when the stock bushing hole is the size of a nickel, I'm sure it can be drilled out to the correct size. Also can the poly rear bushings be split on the flat side for easier installation, like the front sway bar bushings?
Thanks for any help.
