Tonites "slowgress"
Thanks streetrod and janolsson for your very good tips/advice! I spent a few hours out in the brisk 19 degrees tonite
Started out doing a bit of quick organizing and soon realized i was one valve cover bolt short....hmmm of COURSE theres only one place it could be.... in the cylinder head of course. Thankfully I found it and was able to get it out with my magnet, dang thing was so close to dropping off the edge by the rear timing chain and into the abyss. Moving on:
Had a heck of a time getting the top starter bolt cracked loose, mainly cause i didnt have enough room to get anything big with leverage up there. Ended up putting a closed end wrench on it, putting a pipe against the end of the wrench and a couple wacks with my mini sledge did the trick.
Did another round of PB Blaster on the exhuast bolts.
Marked the first visible torque converter bolt with the flywheel.
Not a overly productive night, but i did do a lot of looking and thinking for the trans bolts.
Heres somthing I found:
Guess I'm not the first one in here...? I didn't touch any of the trans to engine bolts, so that one is either loose, or its the wrong bolt and has been bottomed out. You guys know better than me at this point. And am I correct in assuming that both the engine and trans have what i call "junkyard scribble" on them? The trans is kinda hard to see but it does have a faint yellow scribble on it.
Tomorrow I hopefully will get started a lot earlier and manage to get everything completly apart and ready to pull the motor. All i want to have left saturday morning is to remove the hood, undo the last few bolts in the trans and the engine mounts and then lift away!
