mekelly
- October 13, 2014
- Marietta, GA
- 1994 Ford Explorer XLT
My son is soon going to be driving my 1994 XLT. While they are mechanical beasts and anything can happen, I am trying to do as much preventative maintenance as I can to make it as reliable as possible.
What I have recently done:
Replace Spark Plugs
Replace Spark Plug wires
Replace fuel filter
Replace air filter
Cleaned throttle body and MAF sensor
Change trans filter, clean pan, flush 10 qts. fluid, install Magnefine filter
Replaced power steering pump, pressure hose, return hose, flushed system
Replaced water pump, thermostat, radiator hoses, heater hose
Removed blower motor and resister, cleaned debris from heater core
Replaced cracked fan
Replaced fan clutch
Replaced front wheel bearings
The tires are good, battery is good, serpentine belt is good, brakes are good.
The other item I am debating is replacing the fuel pump. Car has 174,000 miles on it. Running fine and hate to spend $100 and mess with it if it's working but a little concerned due to age and mileage. Thoughts?
Anything else I should consider? Don't want to just throw money at it, but am interested in preventing likely failures (given others experience and history)!
Thanks!
Replace Spark Plugs
Replace fuel filter
Replace air filter
Replaced fan clutch
Thanks!
