Remote Anti-Theft Personality Module | Ford Explorer Forums
aldive
Elite In Memoriam
1999 XLT
If replacing the Remote Anti-Theft Personality Module ( RAP ) does one have to reprogram the remote entry key pad on the driver's door and/or the key fobs?
That is the module with the key code on it yes? That module can be swapped at any time. I had two to choose from, I selected the one with a code I prefered.
The PATS module is the one which cannot be swapped casually, just like the PCM cannot be. Those two are married, programmed for each other. Regards,
Al, have you swapped the module? The keypad will match the module code as it is labeled. The keyfob, I'm not sure about that. If the alarm is that module, then I'd say yes the remotes will have to be programmed, but that is very easy.
