Removing Explorer words on sides of car!!! | Ford Explorer Forums
skinz
Rochester, new york
02 XLT
Anyone know how to get the explorer words off the side of a 2002 X. Tryin to see what other people have done. thanks for any help you could give, SKINZ
This same question was asked in the detailing, but haven't had a good answer to it yet....
Use thin fishing line, place between the emblem and body, then slowly pull to remove each letter. You can heat up the emblem slightly with a hairdryer (not too hot) to loosen up the adhesive. There are no pins or mounting tabs.
Mike
what did you use to get the sticky stuff off afterwards??
same stuff that you would use to get tar or bug off.. Would definately recommend a good wax after your done though since its going to take the wax off..
WD-40
