It's very hard to reach with virtually everything in place.
I tried to swap mine for the oil cooler version, and to replace the o-rings. I got the old one off with a lot of frustration by using one hand with a ratchet, and wrench when it was easier in places. Then I discovered the oil cooler short hose cannot be installed without removing the water pump.
So if you have the oil cooler adapter, stop until you're prepared to replace the water pump at the same time.
There is just enough room to get a socket or wrench on the bolt and turn it half a hex side distance, to be able to then reposition and do it again. If you have to do it, it'll take a lot of time, and make your hand sore. But installing it is easier so good luck. I suggest removing more parts before going at it again.
