Removing window tint? | Ford Explorer Forums
Seattle, WA
1988 Ranger
Greetings folks, what is the best way to remove the tint in my Ranger? Thanks...
if its not on the back window: wet and peal, find a corner and pull... and dont forget to scrape when done.
I don't believe that factory tenting is a film type. Not sure it can be removed.
If it's aftermarket film type tint, it's easy to remove. Get a razor blade and start at a corner and peel it up. Grab hold of the loose corner and peel back slowly and the film will come off the window. It'll smell a little funky and tt will leave a nasty, sticky mess on the window. Now you need to get yourself some ammonia diluted in water. Make it pretty strong (I forbet the exact measurements). Spray the ammonia solution onto the glass and leave it sit for a few minutes. Leave your doors open or you'll pass out when you get back in the truck. Now after the ammonia has soaked a few minutes, use the razor blade like a scraper and scrape the glue off the window. It should come right off. Re-apply the ammonia as needed to get all the glue off. After all of the glue is gone, finish the window by scrubbing it with the ammonia mixture, or Windex, on a soft cloth. No problem.
after you peel it off, AMONIA
Another word: don't breath it, you'll kill yourself (dilute it)
Advice: good luck :confused:
