Repacking Wheel Bearings | Ford Explorer Forums
huskyfan23
Rah no Hans Bwix
WA
1994 XLT 4x4
I'm trying to get the inner bearing out of the spindle. Got the plastic cap off, got the metal grease cap, but I just can't get the bearing out. Any special procedure to this?
Sometimes you can get lucky and use a long screwdriver and a hammer and drive the bearing out. They do make a sepecial puller that makes the job a whole lot easier.
Are you replacing the bearing, or just repacking it? If you are just repacking it, I never remove them. Just clean them out with a rag or paper towels and repack them with fresh grease.
Thanks. I ended up just spraying it out with brake cleaner, wiping it down, then shoving a bunch of new grease in there.
