429CJ-3X2
- November 6, 2009
- Des Moines, Iowa
- '01,'02, '04 Sport Tracs,
When I replaced the alternator on my '01 Sport Trac 2 weeks ago I repositioned the clamp on the upper radiator hose so I could get my hand in to the belt without scratching my arm. Since then I've noticed a few drops of coolant under the truck after it's been driven, and thought moving the clamp had somehow broken the seal between the hose and radiator outlet. I drove it to work Friday and went back out a few minutes later and saw coolant dripping heavily. Sure enough, the plastic tank on the radiator had about a 2" hairline crack just above the upper outlet.
I'm an Advance Auto Speed Perks member, so I got online & found they have a radiator with a 2" core for $199. Part # 432559. Yes it still has the plastic tanks. 20% discount for ordering online brought it down to $159, plus I got a reward for $20 off my next $40 purchase. I already had a $20 off $40 purchase reward which I used to buy 3 gallons of antifreeze for just over $7 per gallon. The direct replacement 1" core radiator was $168 before discount. Picked up the radiator on my way home.
The install took longer than expected, but I was in no hurry and I added a heater in the new lower hose for those cold winter mornings. Everything fit perfectly. I was concerned about the fittings for the transmission lines because they stick out farther than the originals, but that was not a problem. The only parts I needed from the old radiator were the clips holding the overflow hose to the radiator and the clip on the bottom for the trans lines. My lower trans fitting was heavily rusted, but I sprayed it with penetrating oil the night before, and it came off with no problem. It does appear to be ever so slightly seeping fluid where the line itself comes thru the fitting, so I'll have to watch that.
TIPS - a stubby 5/8 wrench speeds up removal and installation of the transmission lines. Moving the air intake tube out of the way gives you more room to get the radiator in and out, but isn't a must. I did not remove the fan as someone else said he did. I did have trouble getting the top trans line started due to the angle being slightly off. Turned out the problem was the top line had twisted over the bottom one in front of the engine causing it to bind and not line up right. Repositioned it like it should be, and it lined up to the fitting just fine. The biggest difficulty with this job is the sway bar is in the way of getting the lower hose on and off the radiator. There's just not enough clearance between the lower radiator outlet and the sway bar. I suppose you could have the radiator unbolted while you remove/install the lower hose, but I didn't think of that at the time.
