marvrulz
- December 13, 2015
- 2000 Ford Explorer
Hello. I have a 2000 Explorer, V8 2WD Eddie Bauer edition. I need to replace the ventilation blend door actuator. The one that I removed is part # F87H-19E616-AB. I am having a hard time finding that specific part number anywhere on the web and the Dorman and Standard Motor replacement ones that I find that look like mine say that they are either for manual control (mine is an automatic control) or rear applications (mine has rear controls, but this actuator is in the front), or they have a different shaft (mine has a D shaped shaft with a hole down the center). To top all of this off, A factory repair manual that I have access to says that the part number is 19E616, which the Dorman website pulls back as a part # 604-203, which looks like mine but does not list Explorers in the application list. Can someone please explain if there is a difference between the manual control and rear ones and mine, or even better can someone give me Dorman or Standard Motor part numbers? I want to order the part from the web to dave some money, but don't want to get a part that won't work. I appreciate any help.
