Replacement radiator question | Ford Explorer Forums
aldive
Elite In Memoriam
1999 XLT
Having never had to replace a radiator, I am wondering what is available on the aftermarket.
When I replace, I want to go with a better cooling model than stock.
Input greatly appreciated.
I have a 2 core HD cooling unit. Got it off Ebay. I see no cooling difference in it though. It was a little bigger then the stock 1 I pulled out.
The 96+ models with SOHC and 302 engines have very good radiators, plenty for the stock engines. I may think about a better choice if I do reach 500+hp some day.
Are you having any heat issues, with the pulleys/balancer etc?
No problems whatsoever.
Then why waste money replacing it?:D
I would like to know what is out there--I do seem to have an issue when it is very hot outside,as my coolant will climb to 204, with A/C off. I'm afraid to run the A/C
That is very true, there is less than 4" to begin with.
