bill32399
- August 27, 2009
- Oregon
- 15 Explorer PIU
I use Forscan for everything. You would have to wire the 54 pin in than. It’s not that hard if your doing Sync 3. If you do Sync 2 there a a bunch more wires assuming you want the AV stuff active. All the wires you need are near by but it’s a bit of work the first time for sure.So what you're suggesting is that bc I haven't the sync MyFord already with the 54pin ACM I could at the least plug it in and try? Did you need any dealership programming for your Sony 8" up fit Bill?
