KarmicFlea
- September 19, 2006
- New Baltimore, NY
- 1993 Explorer XLT
Hey all,
I'm in the process of replacing my X's PCV valve and could use some help confirming its connected properly. The replacement part I got is manufactured by/for Champion from Autozone. It is a valve with a double 90 plastic hose connector connected to the top. The PCV I have in there now has no plastic double 90 hose connector on it, and is connected metal to hose only.
I was just going to pull the double 90 connector off the top of the PCV valve and plug it directly into the hose. Can anyone confirm that that is the proper way to install it, or do I need to fix something that someone else screwed up and get it installed properly?
Thanks in advance.
1993 Ford Explorer 4.0L V6 Pushrod
Thanks in advance.
