Replacing V8 badge w/ 5.0 | Ford Explorer Forums
ericautopart
Jersey Shore
1998 XLT 5.0L AWD
Not sure this is body work? On my 98 I'd like to take the V8 off the side of the fender and put a 5.0 badge there. If I remove the V8 badge will there be holes or is it just stuck on there? Has anyone else done this? (I'm sure you have). Do you have a pic?
I have heard that one way to de badge cars is to heat up the badge with a hairdryer or something then move some fishing line back and fort between the car and the badge to like slice through the adhesive.. It supposedly works pretty well, but I have never done it myself.
I just took some of the badges off of my truck. The one in the back has alignment holes as i think the ford in the back would too. The V8 All Wheel Drive that i took off of the fenders is nothing but glue. And like mindless said, heat it up and use fishing line and itll come right off. Any left over glue i found comes right off with Nason reducer. Not sure what paint thinner will do but the Nason took all of it off without disturbing the paint.
I just took my badge off tonight and it was just glued on. I heated it up with a blow dryer, sprayed some WD40 and used a razor blade to take it off. Took all of 5 minutes.:D
^^^^^^^ this is all wonderfull but how can i put the 5.0 badge on and have it hold up to 120+ and the powerwasher as i am an offroader?
