Replacing water pump plate gasket | Ford Explorer Forums
Hartman
Indianapolis, IN
I'm about ready to replace my water pump, but I also want to replace the gasket behind the water pump plate (the one between the water pump and timing cover) just as a precaution. Does this plate just sandwich between the pump and the timing cover via the water pump bolts, or is there additional steps to remove this?
The plate after the pump is removed:
i dont think i ever saw the metallic timing cover gasket leak, ever.
