When the front end is jacked up, and you grab the wheel, it's all over the place. Ball joint's, tierods...are fine. It's the wheel on the spindle.
It was tight last fall when I installed the new bearing set. Now it's sloppy again. Something else is in play here because when I removed the old bearings, they didn't look all that bad. Plus; After I installed the new bearings, I still heard a bad bearing type rumbling noise coming from the same wheel. It continued to get louder over time, and now the wheel is lose as hell again.
That's why I ask how to diagnose this. If the bearings are good, I assume it could only be a poorly machined rotor, or a bent spindle ? Are there any other parts related to this condition ?
