explodermann256
- July 25, 2019
- 2007 Explorer XLT V6 4WD
2007 4.0L SOHC XLT. About to roll 123,000 miles. I really like this truck but it has been plagued with electrical issues since the day I got it. I am the second owner (was an umarked police car, got it from a police auction) and purchased it at 119k.
Anyways, when I bought it, it was discovered that the insulation on the wires leading up to the oxygen sensors on both sides of the truck was completely gone causing the truck to go haywire. Also, the wires leading up to the input speed sensor on the trans had the same issue causing the transmission to shift erratically. At first I thought it's possibly normal since the truck is 12 years old and things do wear out.....
But then, little by little more electrical gremlins began to reveal themselves. The wires leading to the coil pack? Crumbling. The wires leading up to the TPS? Hanging on by a thread and mostly free of any insulation. Alternator connector? Shot.
The truck always had a weird shake and felt like it was misfiring even though I changed the coils/plugs shortly after purchasing it. Last week it began to stall randomly and I pulled a code related to the MAF. I pulled back the tubing on the connector and wires only to find the harness had been repaired twice!!! Also, further back where the harness begins to run along the top of the engine, the insulation on the wires was completely crumbled. I replaced that harness only to find yet more bad wires. This time, it's the wires leading up to the EGR valve connector.
There’s probably more I haven’t even found yet.
Has anyone seen this issue on the 4th gens before? It can't be that the insulation on this many wires are bad, right? The wires under the hood are all nice and pliable on my 2005 Crown Vic, and same thing with a friend's '97 Exp Sport and pretty much every other vehicle I’ve owned that has been older than my Explorer.
