Running 13's in the 1/4 | Ford Explorer Forums
bstjnky
Through the use of a 5.0 swap, has anyone ever reached 13s in the quarter in their Explorer? I am seriously thinking about putting in a 5.0. Does anyone make motor mounts and all necessary hardware for the installation? How much of a difference will the motor make over the 4.0? Will a C-4 tranny fit? Sorry about all of the questions, but I wanna get as much info as possible before even thinking about this. It turns out a buddy of mine has a 5 liter motor that was pulled from his car laying in his garage. He is going all out, as in a 460. He says i can have the motor-the whole thing-for $1500. It has a ton of bolt ons and only 45,000 miles. It came out of a 92 LX. If the C-4 doesn't fit, will the AOD? It'll be going in a 93 4 door. How hard is the swap? Any suggestions would be appreciated.
Thanks, Jason
Also, what about a rear-end? Any posi units available?
I doubt if I can answer all your questions, but I can tell you what little I know (and hopefully, someone has experience with this mod on an Explorer). I had a '90 Mustang LX 5.0. Magazines put it in mid-14's stock, which is pretty quick. Keep in mind though that that's with factory headers, roller cam, and dual exhaust. I'm pretty sure that with some reasonable modifications, that 225 HP engine could easily reach 275. I'm talking bolt-ons like intake manifold, larger throttle body and MAS sensor, better headers, free flowing exhaust and high flow cats. That is enough to get it into the mid 13's in a Mustang. But, keep in mind that a Mustang of that era only weighed about 3200 pounds; an Explorer weighs 4000-4500 pounds.
So, I'd say that with maybe a little extra cam, and a high stall converter, along with 4.10 gears (limited slip is available in many forms for the 8.8" rear end), you could get that Explorer down there. As far as bolting up the C-4, look at advanced adapters. I'm sure that the C-4 hooked up to the 5.0 in some vehicle or another over the years, so that part shouldn't be hard. Adapting it to the rest of your drivetrain may take some fabrication, though. (My friend's brother used to race Mustangs, so I've seen the results)
Of course, with that much power, you may want to opt for a tougher tranny. The C-4 is a lighter duty transmission, though it is used quite a bit in racing (probably its light weight, and there's lots of them around). I don't know how the newer A4LD and such compare in strength. Hopefully, someone here with a V-8 Explorer can give you more insights into making this work.
Take this advice with a grain of salt; The only engine I modified to any degree was a 2.3L 4 cylinder. Cam, header (only one), and a bigger carb primarily. It was pretty quick, but was weak at low RPM's. Would rev right off the tach, though. Dead Link Removed
Check Dead Link Removed for the multitude of parts available for the 5.0. They have a whole section in their catalog for that.
Oh, one other thing, a tall intake manifold will not fit under the standard Explorer hood. Some of those performance manifolds are pretty tall. Also, stick with fuel injection, don't go carb unless you are going to go all out. They're a pain compared to injection.
Tom
99 Sport 4x4
SOHC
Auburn Rear & Gerald's old Shackles
So would a 3.73 gear, upgraded exhaust, ignition, air intake, upper and lower intake, cam, pulleys, headers, injectors, and a fuel pump possibly do this? The motor I can get my hands on has all of this minus the gear, exhaust, and fuel pump. I plan on lowering the Explorer with Eibachs and putting Tokicos or Bilsteins all the way around before I do the swap, along with 17 by 9 Cobra R's. I want the fastest 1st gen Explorer around, and plus I think it'll be neat to have a V8 Explorer that could pull on most of the factory sports cars. Any tips?
Thanks, Jason
How about doing that with a 4.0? Thats my goal. HEHEHE
Tony 91 Sport
Flowmaster
Custom conical K&N filter
MSD
Accel wires
Bosch Plugs
Cometition Cam
Ported-n-Polished
Bored .40 over
13's . . . . .
I hope after my supercharger that I could be there. But I Have a 97 sport which is lighter to begin with. I have a 4.10 posi rear, Cold air intake (ben jenkins) Flowmaster 50 series dual exhaust, superchip and a performance Mass air and i went 15.0 flat. I am itching for the supercharger now.
This may not help much, but to show you the great potential of the 302 roller motor. I had an 89 302roller motor with over 100,000 miles on it in a 83 gt stang. stock bottom -end ported stock heads edelbrock performer rpm manifold and a b-303 cam and c-4 trans 650cfm carb. It ran 12.30s at 103mph. I never hurt the motor, the guy I sold it to put the juice on it and went 11.17 and did not hurt the motor. The c-4 trans will bolt up it has been used with the 302 alot.
