Running board repair? | Ford Explorer Forums
aldive
Elite In Memoriam
1999 XLT
I accidently ran over a larg rock while at Blue Grotto ( Williston, FL ). The only damage is that my passenger side running board is bowed upward a couple inches in the center.
Ideas and suggestions for a fix are sought.
Thanks....
Al, not sure if yours are the same as mine, but,,, there are 4 'L' brackets that mount the boards to the chassis. If one of those are bent, replacement/repair should be easy and cheap.
If the corrigated support under the board itself is bent, you'll probably have to get a whole new board. At the very least, repair would be a PITA.
Good luck!
If it is aluminium it is bent for life :(
Adjusting the L brackets may offer some help.
Other wise, lay it on flat concreat, remove the rubber pad and go to town with a dead blow hammer.
We usually just replace bent running boards.
Best of luck.
Thanks....
Is the OEM running board fiberglass or plastic? I know Gerald has claimed a few to rocks and i'm not sure if you can fix the stock ones :(
I've got absolutely no clue what they sell for. I looked on ebay and the board and didn't see any for sale or any prices. PM me and make me an offer.
