ranger7ltr
- November 17, 2001
- Great State of Texas
- 1999 Sport
After running rich for a while...
You may need to replace the plugs since they might be fouled with carbon...Getting some gas mileage back is a good sign though..Plus the extra fuel being burned MIGHT have caused a problem with the o2 sensors and the convertors...
Did you also check the voltage output of the ACT sensor as well? If there is carbon build-up in the exhaust it should clear out after a few hundred miles...
Actually these sensors shouldn't care what the adaptive memory has stored since each time the engine runs the parameters will change and the stored adaptive memory will change...But the adaptive memory is being relearned after pulling the battery cables and removing the battery voltage erases the Keep Alive Memory and you will need to drive it in various situations for the PCM to relearn your driving habits...
Drive the truck for a while and see if the conditions change over time...I would continue to use whatever fuel you normally use and drive like you would normally drive...
